Smart_user
Feb 16, 2022Follower
CAX80 warranty
NETGEAR closed my warranty case 3 days before the warranty expired without solving the problem. The issue was a known issue - no WIFI calling with Samsung phones, wifi calling works okay iwth IPhone...
Feb 16, 2022Guru - Experienced User
sadly, its something you'll have to go through support for if its a warranty claim.
The wifi calling is a different issue. If you do a quick search on samsung wifi calling not working, you'll find a ton of results.
