toflyformywifi's avatar
Sep 14, 2020
Cellular Failover AX200
I am working from home and need to have consistent connection. I have a RAX200 router and have a CenturyLink connection. I also have a Netgear Nighthawk LTE modem that my work provides. Is there a way to configure the RAX200 to fail over to LTE if my main connection fails? Some thoughts I have had is maybe buying an ubiquiti product or something similar to accomplish this if there is no way to configure it on the device.
1 Reply
  • plemans's avatar
    the only netgear consumer router I know that supports failover is the R7100L.
    You could configure the hotspot to output to the router and just switch it yourself when the centurylink goes down.
    Or even hardwire in your pc to the RAX200 and link it via wireless to the hotspot. maybe you can configure the pc for failover
