nlq44261
Mar 02, 2021Aspirant
Centurylink Fiber config Nighthawk RAX120
I'm having trouble with the configs for my RAX120 so that it will establish a link with Centurylink Fiber. I can't get it to work unless I connect it to the Centurylink provided router and turn off P...
antinode
Mar 02, 2021Guru
> In ADVANCED>Advanced Setup>VLAN / Bridge Settings [...]
Someplace in some CenturyLink instructions, a VLANID of 201 was
mentioned?
I know nothing, but I suspect that you're fiddling with the wrong
VLAN stuff. I'd clear that stuff out, and investigate:
ADVANCED > Internet Setup : Use VLANID (and the box for the ID number).
- nlq44261Mar 03, 2021AspirantThere is no VLANID entry in ‘ADVANCED > Internet Setup’ on the nighthawk rax120 web configuration page. There is only a link at the end of the ‘Internet Setup’ page to send you to the ‘ADVANCED > Advanced Setup > VLAN / Bridge Settings’ page to configure the VLANID.
All the VLAN config mentions I’ve seen tell you to make the change on that page using the ‘By VLAN tag Group’ toggle- nlq44261Mar 03, 2021AspirantHere’s a photo of my VLAN settings as well
