nlq44261
Mar 02, 2021Aspirant
Centurylink Fiber config Nighthawk RAX120
I'm having trouble with the configs for my RAX120 so that it will establish a link with Centurylink Fiber. I can't get it to work unless I connect it to the Centurylink provided router and turn off P...
nlq44261
Mar 03, 2021Aspirant
There is no VLANID entry in ‘ADVANCED > Internet Setup’ on the nighthawk rax120 web configuration page. There is only a link at the end of the ‘Internet Setup’ page to send you to the ‘ADVANCED > Advanced Setup > VLAN / Bridge Settings’ page to configure the VLANID.
All the VLAN config mentions I’ve seen tell you to make the change on that page using the ‘By VLAN tag Group’ toggle
nlq44261
Here’s a photo of my VLAN settings as well
