nlq44261
Mar 02, 2021Aspirant
Centurylink Fiber config Nighthawk RAX120
I'm having trouble with the configs for my RAX120 so that it will establish a link with Centurylink Fiber. I can't get it to work unless I connect it to the Centurylink provided router and turn off P...
nlq44261
Mar 03, 2021Aspirant
I forgot to post the last bit of settings that could affect connectivity. Here they are:
ADVANCED > Setup > WAN Setup
Disable Port Scan and DoS Protection: feature disabled
Default DMZ Server: disabled
Respond to Ping on Internet Port : feature disabled
Disable IGMP Proxying: feature enabled
MTU Size(in bytes): 1492
NAT Filtering: Secured
Disable SIP ALG: feature disabled
I’ve tried NAT filtering in both ‘Secured’ and ‘Open’ settings but I haven’t gotten to the point where this router is pulling a public IP address from centurylink
