RJMW62's avatar
RJMW62
Chanel set up 2.5 GHz & 5 GHz - which channels to use and do I overlay my HUB & AX6000?
Hi just set up an AX6000, need to fine Tune. It is an extremely basic question I need to know. Do I set up the 2.5GHz & 5GHz channels to be the same on the cable Hub and the AX6000 or not? If n...
