BVDpa
Feb 01, 2020Aspirant
Change Device Connection Type
How do I change the connection type for a device that is connected to the wrong connection? I currently set up both 2.4 GHz and 5 GHz connections. When I originally set up my network I was able to ...
BVDpa
Thanks for replying to my question.
I did not set up smart connect because I wanted to control the connection types to my various devices which was easy to do. Unfortunatly, now that I would like to make a couple changes, I cannot figure out where to accomplish this task.
Feb 03, 2020Guru - Experienced User
This article walks you through it.
https://kb.netgear.com/23439/How-do-I-change-my-NETGEAR-router-s-WiFi-password-or-network-name-SSID
- BVDpaFeb 03, 2020Aspirant
Thanks but this article does not address my situation.
- plemansFeb 03, 2020Guru - Experienced User
Then I guess you need to better describe what you're trying to do so I understand it.
Hi,
When I originally set up my home network with the RAX80 wireless router I set up both a 2.4 GHz and a 5 GHz connection option for my network and I originally manually assigned my devices to the appropriate speed network connection types. It was easy to do but now I want to change a couple connections and I cannot figure out how to change the connection type. Thanks for your patience and help.
