danbrett113
Sep 25, 2023Follower
Change the UDP Timeout on RAX 200
I'm being asked to change my UDP timeout to 300 by my VOIP provider. Is there a way to do this on the RAX200? Thanks
Sep 25, 2023Guru - Experienced User
I don't think so.
Are you using a VoIP device thru the RAX router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
