Rayzorx
Aug 27, 2023Aspirant
Changed to use https for admin, now can't login
I just changed the Admin login to use HTTPS. I was able to login once using Chrome and Firefox, and got the warning messages about the cert. Now, neither one of the browsers works for logging in. They never seem to find the router. In Chrome, I get "Site Can;t Be. Reached" in Firefox I get
Secure Connection Failed
An error occurred during a connection to 192.168.1.1. PR_CONNECT_RESET_ERROR
Any ideas on how to resolve this?
RayK
If you can't get in with HTTPS://192.168.1.1 then you'll need to factory reset it.
Factory reset the router and setup from scratch.
- RayzorxAspirant
Thanks Furrye38,
I was hoping to not have to do that, but I do have a recent saved config so it might mot be too painful.đ©
