bd2
May 09, 2020Aspirant
Changing modem for my RAX45
I am thinking of upgrading my modem. I currently have a Nighthawk AX4300 6 Stream router. What kind of setup work will I have to do with the router once I change the modem?
May 09, 2020Guru - Experienced User
The best bet?
Check with your isp to see what's compatible. We can recommend all kinds of things but if its not compatible with your isp, its a bit pointless.
antinode
May 09, 2020Guru
> I am thinking of upgrading my modem. [...]
From what to what?
> [...] What kind of setup work will I have to do with the router once I
> change the modem?
If all you're doing is a modem swap, then I wouldn't expect any. If
your (unspecified) "my modem" were actually a modem+router, then things
might get more complicated.
Your ISP might be interested in the MAC address of the new modem, but
I don't see why the router would care about such a change.
- bd2May 09, 2020Aspirant
I am currently using a Motorola Surfboard SB6121 modem (modem only) which my RAX45 router is connected to. I want to change that out for the CM1100. I didn't know if I would have to change any settings on the router once I switched over. Or if it just entailed restarting the router after the new modem was installed.
- plemansMay 09, 2020Guru - Experienced User
It *should* work fine with a reboot in the proper order once the modem is activated.
I say should because stranger things have happened.
