Mariela
May 27, 2021Follower
Changing the password
how to change the password on the router
May 27, 2021Guru - Experienced User
what router? (model)
Password for the wifi?
Password to log into the router?
if you go to netgear.com/support/
type in your model number.
it takes you to guides, firmware, and manuals. All that can walk you through changing wifi or gui password
