Explorz
Dec 27, 2023Tutor
charger connector diameter RAX50
I need to buy a replacement adapter charger for my RAX50. Does anyone know the proper barrel connector diameter? It's 5.5MM outer. But is the inner 2.5mm or 2.1mm? Thank you.
Dec 27, 2023Guru - Experienced User
One of these should work:
