drugrep
Jun 05, 2021Aspirant
Check for update failing (1.0.2.82 to 1.0.2.94)
(Using RAX45, model selector above won't let me select that version. the following has been true of past 2 updates also. I noticed today 1.0.2.94 was posted. I had the router check for up...
Jun 05, 2021Guru - Experienced User
sometimes the manual update server gets the update prior to the auto-update server.
And sometimes its opposite where the auto-update gets it first.
Not sure why it works like that.
- drugrepJun 05, 2021Aspirant
Well, neither had it and I had to manually download it from the website.
