JimmyW
Jan 05, 2024Luminary
Chrome blocks attempts to backup settings
I just set up my AX5400 and want to backup my settings, but Chrome objects as it's considered "insecure content." I can get around it by electing to download it anyway, but I cant find an option in chrome to whitelist the address. Thanks.
This is the RAX54S?
AX5400 is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
You are using a web browser and the graphical user interface (GUI)? In Windows?
At what stage does Chrome object?
Browsers are getting picky about security, especially with http sites, even though they are local and unlikely to bring about Armageddon.
If you can't find anywhere in the Chrome world that tells you what to do, try a different browser.
Firefox and Edge may throw up security warning, but they will let you save the file. Just follow their instructions.
Chrome also offers this option:
This is the RAX54S?
- JimmyWLuminary
Thanks. I'm running Chrome on Win 11. According to the box, the model is an RAX50-NAS. I was hoping to find a way to simply whitelist the address for the future.
That's a challenge for Chrome, not your router.
Let us know if you find the answer there.
