Sanjith92
Aug 20, 2021Star
Chromecast and Mesh problem AX1800 MK63
Need support for Chromecast not working with Mesh setup AX1800 MK63 . If my phone and chromecast are connected to same satellite , Cast will not work . It only works if my phone is connected to the...
- Nov 30, 2021The recent firmware v1.1.6.122 fixed this issue
Nov 30, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy.
