CL7's avatar
CL7
Initiate
Aug 30, 2020
Chromecast cannot connect to MK63
I succesfully set up a home network with MK63. All devices connect except Chromecast. I did a factory reset of Chromecast. I ran the setup in Google Home. Chromecast found the SSID but then it gave ...
  • CL7's avatar
    Aug 30, 2020
    I figured it out, I had to go into Advanced...Setup...Guest Network...
    and uncheck Enable SSID Broadcast
