jimerb
Jul 04, 2023Aspirant
Cielo Breez Plus Keeps Disconnecting From Wifi
I'm trying to get this Cielo Breez Plus Smart Air Conditioner Controller to not disconnect every 10-15 minutes. The device will only connects only to a 2.4ghz channel. It connects fine but then d...
Kitsap
Jul 05, 2023Master
jimerb wrote:I'm trying to get this Cielo Breez Plus Smart Air Conditioner Controller to not disconnect every 10-15 minutes. The device will only connects only to a 2.4ghz channel. It connects fine but then drops. The device is about 10 feet away from my Nighthawk RAX200 router. The device itself has no options for connecting -- it's very basic.
Can anyone give me some suggestions on what I can tweak on the router side? My current config:
- 20/40mhz coexistance unchecked.
- Broadcasting on channel 1
- Mode up to 1200 mbps
- Transmit power control 100%
- Fragmentation Length: 2346
- CTS/RTS Threshold: 2347
Cielo's tech support is not being much help.
Can anyone give me some guidance? Things to try?
A couple of suggestions for testing.
Change the broadcast channel. Next best options are channel 6 or channel 11.
Lower the transmit power to 25% or 50%, you may be overwhelming the controller with signal.
Enable the 20/40 coexistance.
jimerb
Jul 06, 2023Aspirant
Thank you! I will try these things. Most of these settings are way over my head.
