Riyadh
May 10, 2019Tutor
Circle on AX4
I just bought AX4 to replace the old AC1900. I use Circle from Disney to control the internet at home. AC1900 is compatible with Circle. I was surprised that AX4 is not compatible with Circle. I cann...
schumaku
May 10, 2019Guru - Experienced User
Circle is suppored on select router models only - as of writing, there are no Netgear WiFi 6 AX (RAX xx) models on the list. Vaguely discused here already -> https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/Circle-with-Disney/td-p/1739930 not information on plans and availbility by Netgear however.
- RiyadhMay 10, 2019TutorThank you very much for your message.
I wish someone from Netgear answer our questions..- schumakuMay 10, 2019Guru - Experienced User
Christian_R ChristineT please...
- Christian_RMay 10, 2019NETGEAR Employee Retired
Hello Riyadh - Thank you for your interest in Circle on the AX4. Circle is being discussed on the AX routers but we do not have more details or an ETA at the moment.
~Christian
- RiyadhMay 10, 2019TutorThank you very much Christian.
Unfortunately I, I cannot install my new RAx40 unless it is compatible with Circle, otherwise I will return it.
Regards.
