SanderWolf
Oct 31, 2020Aspirant
Circle stops working on RAX75
I'm running a nighthawk RAX75. I have the latest firmware. I am using the built in circle. Ever since I updated to the new firmware Circle doesn't work consistantly. It stops enforcing bedtimes a...
Christian_R
Nov 05, 2020NETGEAR Employee Retired
Hi SanderWolf,
You may check to see if your router is due for a firmware update. The article below may help address your history usage issues.
https://support.meetcircle.com/hc/en-us/articles/360026374272-Missing-Usage-or-History-Issues
Christian
- SanderWolfNov 05, 2020Aspirant
I did check the firmware -- I'm at the latest.
- Christian_RNov 06, 2020NETGEAR Employee Retired
Hi SanderWolf,
Did you have a moment to try the suggested steps from the Circle article?
Christian
- SanderWolfNov 06, 2020Aspirant
I'm not sure what steps you mean... I'm at the latest version of the firmware already.
I have all of my devices pinned to the right users.
Circle is still not enforcing offtime and bedtime.
I don't know what else to try. Perhaps I should downgrade the firmware?
