Zvampire
Apr 20, 2019Follower
Circle with Disney
Can anyone tell me if Parental Controls or Circle with Disney will be coming out for this router ?
RAX80
michaelkenward
Apr 21, 2019Guru - Experienced User
I may mean not much, but the Data Sheet for the RAX80 already boasts:
"Once set up, you can use the intuitive dashboard to pause the Internet on your connected devices, run a quick Internet speed test, setup smart parental controls and much more!"
If it doesn't work, then you should shout long and loud at the Netgear people about misselling this device.
Jeremyinsf
Apr 21, 2019Apprentice
I see the RAX120 data sheet (under the Nighthawk App section) specifically states:
Smart Parental Controls—Easily manage content & time online with Circle® with Disney
The actual Circle language is missing from RAX80 data sheet (on Netgear website).
Regardless, If they are going to offer it, I'd imagine it will be on all similar models. Perhaps at this point, they have just not integrated it into the new firmware. As others have stated here, there are still a few published features missing.
