Zvampire
Apr 20, 2019Follower
Circle with Disney
Can anyone tell me if Parental Controls or Circle with Disney will be coming out for this router ?
RAX80
michaelkenward
Apr 21, 2019Guru - Experienced User
I may mean not much, but the Data Sheet for the RAX80 already boasts:
"Once set up, you can use the intuitive dashboard to pause the Internet on your connected devices, run a quick Internet speed test, setup smart parental controls and much more!"
If it doesn't work, then you should shout long and loud at the Netgear people about misselling this device.
Jonsnow
Jul 03, 2019Aspirant
Anyone know where you find parental controls in the Admin interface?
michaelkenward wrote:I may mean not much, but the Data Sheet for the RAX80 already boasts:
I also would like Disney Circle present on the router as it was so beneficial on my old one! If the Netgear Engineers are reading (I know you are) please add this feature. Thank you!
Anyone know where I can find parental controls in the admin controls??
