Pedro20
Sep 23, 2021Follower
Client VPN is not workable?
hello my router ax20 v1.2 firware updates to 1.3.1 Build 20210521 rel.72481(5553) Still It can not connect to vpn server please check thx
Wall252
Sep 24, 2021Aspirant
Either restart or reinstall your VPN client. Use a faster VPN protocol, and a different network port. Check if the VPN server is up and running. Restart, reinstall, or update your web browser if you're using a VPN extension.
