Pedro20
Sep 23, 2021Follower
Client VPN is not workable?
hello my router ax20 v1.2 firware updates to 1.3.1 Build 20210521 rel.72481(5553) Still It can not connect to vpn server please check thx
Razor512
Sep 24, 2021Prodigy
If using the VPN server, make sure that you know your WAN IP (dynamic WAN IPs will occasionally change), or use a dynamic DNS service such as no-ip.
If you need to access both your local network and internet through the VPN server, then change the mode from "Auto" to "All sites on the Internet & Home Network"
On mobile devices, the OpenVPN connect app is able to automatically configure everything for you when you import the profile, but on windows, additional steps are needed to properly route the VPN traffic to the VPN server.
For example, on windows, the adapter that the OpenVPN client installs, needs to be renamed to NETGEAR-VPN (case sensitive).
