mrkentwa
Oct 26, 2021Aspirant
Clients Frequently Disconnect from RAX50
Updated to try to select proper product but the AX5400 isn't in the list.
I've got a RAX50 running firmware V1.0.2.82_2.0.50. I've checked both the router and my primary computer for updates and none are available.
I have about 30 devices connected to it across both the 2.4 and 5GHz radios.
Randomly today, all the clients will disconnect and then reconnect within a minute or two. Logs show a bunch of DoS attack events (ACK Scan, RST Scan and Fraggle Attack) from a variety of sources but that seems pretty continuous throughout the day and doesn't show any increase immediately preceeding the disconnect.
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
