mrkentwa
Oct 26, 2021Aspirant
Clients Frequently Disconnect from RAX50
Updated to try to select proper product but the AX5400 isn't in the list. I've got a RAX50 running firmware V1.0.2.82_2.0.50. I've checked both the router and my primary computer for updates and non...
Oct 27, 2021Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 to 161 channel on 5Ghz.
- mrkentwaOct 27, 2021Aspirant
Using an Arris Surfboard SB8200 instead of Comcast's supplied modem.
As far as channels, I'm using auto. The devices that are dropping off are all on the 5GHz radio. I tried manual after scanning the area for noise on the different available channels but auto was already using the quietest channels.
There are 2 nearby networks but both are weak signals.
Just to be clear, the NG router doesn't lose internet access, it just kicks all clients off. Almost like the radio is cycling off and back on really quickly.
- FURRYe38Oct 27, 2021Guru - Experienced User
What channels are you using now?
Has a factory reset and setup from scratch been performed since last update?
I set it back to auto and is selected 6 and 48.
I did a factory reset of both the modem and router when the issue first started (after I tinkered with a bunch of settings to no avail)
