mrkentwa
Oct 26, 2021Aspirant
Clients Frequently Disconnect from RAX50
Updated to try to select proper product but the AX5400 isn't in the list. I've got a RAX50 running firmware V1.0.2.82_2.0.50. I've checked both the router and my primary computer for updates and non...
mrkentwa
Oct 27, 2021Aspirant
Using an Arris Surfboard SB8200 instead of Comcast's supplied modem.
As far as channels, I'm using auto. The devices that are dropping off are all on the 5GHz radio. I tried manual after scanning the area for noise on the different available channels but auto was already using the quietest channels.
There are 2 nearby networks but both are weak signals.
Just to be clear, the NG router doesn't lose internet access, it just kicks all clients off. Almost like the radio is cycling off and back on really quickly.
Oct 27, 2021Guru - Experienced User
What channels are you using now?
Has a factory reset and setup from scratch been performed since last update?
- mrkentwaOct 27, 2021Aspirant
I set it back to auto and is selected 6 and 48.
I did a factory reset of both the modem and router when the issue first started (after I tinkered with a bunch of settings to no avail)
- FURRYe38Nov 02, 2021Guru - Experienced User
Can you disable AX mode on 2.4Ghz and 5Ghz radios by chance?
Also try turning down the power output of the wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- mrkentwaNov 02, 2021Aspirant
I tried disabling AX and reducing the radio power. Neither of those produced noticable results. At this point, I appreciate all the help but I've got to be able to work and my kids need consistent connection for school so I'm just going to return this and try something different.
