mrkentwa
Oct 26, 2021Aspirant
Clients Frequently Disconnect from RAX50
Updated to try to select proper product but the AX5400 isn't in the list. I've got a RAX50 running firmware V1.0.2.82_2.0.50. I've checked both the router and my primary computer for updates and non...
Oct 27, 2021Guru - Experienced User
What channels are you using now?
Has a factory reset and setup from scratch been performed since last update?
mrkentwa
Oct 27, 2021Aspirant
I set it back to auto and is selected 6 and 48.
I did a factory reset of both the modem and router when the issue first started (after I tinkered with a bunch of settings to no avail)
- FURRYe38Nov 02, 2021Guru - Experienced User
Can you disable AX mode on 2.4Ghz and 5Ghz radios by chance?
Also try turning down the power output of the wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- mrkentwaNov 02, 2021Aspirant
I tried disabling AX and reducing the radio power. Neither of those produced noticable results. At this point, I appreciate all the help but I've got to be able to work and my kids need consistent connection for school so I'm just going to return this and try something different.
- FURRYe38Nov 03, 2021Guru - Experienced User
đ
