alduxo's avatar
alduxo
Follower
Sep 16, 2020
clients rederect on connection
Hi guys,
I have bought a ax12 - 12 stream ax wifi router and I need to use it on my restaurtant.
I need  the client who connects via wifi to be rederected on the website of the my restaurant.
After that rederection they can navigate where ever they need to.
Is that anyway to do it ??
Best regards
Aldi
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    HI Aldi,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    http://www.netgear.com/support/contact.aspx
    Christian
