Shockwave2211
Jul 02, 2020Star
CM1000 modem with WiFi 6 routers
Purchased a TP Links AX6000 and the modem starting having issue. Called cable company and they denied issue. Logged is as said and it did reflect some potential cable issues. However in an attempt...
- Jul 02, 2020
I personally would avoid anything TP-Link.
I recommend you try this, get on amazon and find a NG model RAX router, try a RAX80. Amazon has good return policies and usually you have 30 days to try something out. Give a RAX a try with your CM1000. Be sure the modem signals are Good. Besure to use CAT6 LAN cabling between the modem and router and router to wired devices. I would first test the RAX out with what ever FW was loaded on it first, or you can load latest FW. Try something out and see how it goes.
Another consideration is that do you need AX at this time? Can you fully take advantage of AX? Would a AC class router suffice as well?
Jul 02, 2020Guru - Experienced User
Shockwave2211
Jul 02, 2020Star
I think I will try another router as you suggested. I bought this one from Amazon and it is going back there.
I have been doing a good amount of home automation and currently have over 30 devices on the network. Do I "need" the WiFi 6 now. Things are working OK they way they are but I know I am only going to grow. This stay at home period has turned my wife and I into automation monsters so I want to take it to the next level.
- FURRYe38Jul 02, 2020Guru - Experienced User
Ok then, sounds like a good project to test out. Hope it works out for you.
- Shockwave2211Jul 05, 2020Star
Well that did not work. Sent back the TP Links AX6000 and bought the Netgear RAX80 as suggested. Same exact problem is occuring.
It all worked well with the Older Netgear AC rougter all weekend. Sunday recieved the RAX80 router and immediately started having issues with the modem. Like the topic of this thread says... it is like this Modem is unable to handle WiFi 6. Please help if anyone is able.
- FURRYe38Jul 05, 2020Guru - Experienced User
Possible you just have a faulty modem. Please contact NG support and ask for additional help and information. Ask about an RMA.
This model modem can handle a wifi 6 router connected.
