Pangarkar
May 08, 2020Follower
CM1100 and Link Aggregation
Hello, Needing some help with trying to set up Link aggregation for my Netgear system. Recently purchased the Nighthawk AX6 AX4300 Wifi6 router at Costo because our slightly older Nighthawk 79...
May 08, 2020Guru - Experienced User
Are you paying for >1 gig speeds?
If you're not, I'd proably just skip link aggregation. Its a nice feature and worth it if you have >1gig speeds but otherwise, its isn't much benefit and only adds complexity.
that's just my experience from using link aggregation. Its been a headache and not just isolated to netgear.
