devdelimited
Mar 24, 2020Tutor
CM1100 and RAX120 Interference
Since the other thread was closed for comments, I wanted to post that this is still very much an issue. https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/CM1000-Modem-and-RAX120-r...
- Mar 24, 2020
devdelimited wrote:Since the other thread was closed for comments, I wanted to post that this is still very much an issue.
It would appear that the CM1100 is insufficiently sheilded - at least not well enough to prevent the RAX120 from knocking it offline when the two are in close proximity. How close? You'll just have to play with it. For me, a few inches was too close, and about 2 - 3 feet was fine.
Thanks to thenorn_2012.
I have found that vertical clearance helps. You can have them really close with one above the other. I have my router on a shelf just about the modem now. I have not experienced any addtitional issues since my initial post. The router and modem are both rock solid, assuming the modem isn't near the router antenna.
thenorn_2012
Mar 24, 2020Tutor
devdelimited
Mar 24, 2020Tutor
Your teachings are wise. I, too, have elevated my RAX120 with effective results.
