devdelimited's avatar
Mar 24, 2020
CM1100 and RAX120 Interference
Since the other thread was closed for comments, I wanted to post that this is still very much an issue.   https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/CM1000-Modem-and-RAX120-r...
  • thenorn_2012's avatar
    Mar 24, 2020
    https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/CM1000-Modem-and-RAX120-radio-interference/m-p/1779154/highlight/true#M2221
    It would appear that the CM1100 is insufficiently sheilded - at least not well enough to prevent the RAX120 from knocking it offline when the two are in close proximity. How close? You'll just have to play with it. For me, a few inches was too close, and about 2 - 3 feet was fine.
    Thanks to thenorn_2012.
    I have found that vertical clearance helps. You can have them really close with one above the other. I have my router on a shelf just about the modem now. I have not experienced any addtitional issues since my initial post. The router and modem are both rock solid, assuming the modem isn't near the router antenna.
