Rwoody
Dec 11, 2019Aspirant
CM1100 to R7960P router using LAN aggregation to a 4 and 8 port unmanned switch
Hey Guys (Gals) I'm trying to figure out how to set up my home network the best. I just got the modem and router and noticed LAN aggregation between the two but then I only have two ports left for wir...
Dec 11, 2019Guru - Experienced User
You should have 3 ports left. theres 1x wan port and 4x lan ports. One of the lan ports is used to aggregate the wan and lan port for link aggregation. this should leave 3 ports. and yes you can attach unmanaged switches to these other ports without issues.
That'd be kind of ideal.
- RwoodyDec 11, 2019Aspirant
Hey thanks I needed some assurance and my math left much to be desired ... It's funny I did everything but count the router jacks on my hand, haha. Is there anything you would do different? Please let me know I'm going to change it over tomorrow as I've already reached my cuss limit just setting it all up already, thank god for WPS!!
- plemansDec 11, 2019Guru - Experienced User
If you're going CM1100---->R7960----->devices/switches, you'll be fine. Unmanaged switches are pretty set and forget.
