Slipknotter
Aug 31, 2019Follower
CM1150V & AX8 internet connection issues
Ok here it goes. I have been dealing with computer hardware for the better part of 20 years now and I have never had this issue before. First off I recently received my CM1150V (8-29-2019) I activated...
Aug 31, 2019Guru - Experienced User
I recommend you post about this over in the RAX router forums.
Good Luck.
