Ngregsak
Dec 14, 2020Guide
cm1150v modem with rax20 router keeps dropping internet every night with xfinity service
I have been losing internet connection every night and having to reboot my modem and router every morning. It works fine during the day and evening but during the night it drops the connection and I ...
Dec 15, 2020Guru - Experienced User
so modem connection is stable.
What firmware is on the router?
Ngregsak
Dec 15, 2020Guide
firmware on router is V1.0.2.64_2.0.42
- plemansDec 15, 2020Guru - Experienced User
have you tried a factory reset and clean install (not from a backup configuration) on the rax20?
- NgregsakDec 15, 2020Guide
no i have not. how do i do a clean install?
Its a standard install but you just make sure not to use a backup configuration
- NgregsakDec 16, 2020Guide
I DID A SYSTEM RESET AND CLEAN INSTALL. WILL SEE WHAT TOMORROW BRINGS
- NgregsakDec 17, 2020Guide
lost internet again this morning and had to power off and power on
- plemansDec 17, 2020Guru - Experienced User
try downgrading the firmware to version 1.0.1.58. do a factory reset and clean install and disable auto-updates.
- NgregsakDec 18, 2020Guide
internet did not drop over night. appears to be working fine.
- plemansDec 18, 2020Guru - Experienced User
glad to hear it!
- NgregsakDec 20, 2020Guide
the issue is still continuing. it happened this morning and yesterday morning.
- plemansDec 20, 2020Guru - Experienced User
did you downgrade the firmware?
yes, did a factory reset of the router and am on firmware V1.0.1.58_2.0.31 and have disabled autoupdates. also did a factory reset on the modem as well.
do you have ipv6 enabled?
YES, it is enabled on my computer. or do i need to enable it on the router/modem also? if so, how do i check that
IPv6 IS DISABLED on the router
Try enabling it.
