irishx007
May 08, 2020Follower
cm1200 and rax80 for xbox one x
im at a lost and looking for hope, i have the cm1200 modem with the rax80. how does one set up 2 xbox one x, same house both hard wired thru router ,to where father and son can get indivdual ports t...
May 08, 2020Guru - Experienced User
The cm1200 has 4 ports on it.
For the average user though, only 1 port is worth hooking up.
here's why.
ports 1-2 can be used for port aggregation. Which has had stability issues with most manufacturer's. Unless you have speeds >1gig, i'd avoid.
ports 3-4 can only be used if your isp allows multiple public ip addresses. Most don't. Its rare to find.
so the average consumer is only going to use port 1.
which is why I usually recommend the cm1000 or cm1100 for most.
are you going cm1200------->RAX-------xbox's?
