4estOC
Jan 08, 2020Guide
CM1200 to Rax200 WAN aggregation slows down (requires reboot)
I have a CM1200 modem and RAX200 Router with WAN agreggation (2Gig). My internet speeds slow down to 25Mb after approx 24 hours. Rebooting the router fixes the issue for another 24 hours and then the...
Bosko22
Mar 18, 2020Tutor
Yes, that is what I had to do. But I would naturally prefer to use all the bells and whistles that are supposed to be part of this system. Am I right in assuming there is no fix but to wait for a firmware upgrade?
Shelby500GT
Mar 20, 2020Aspirant
All -
I have the same issue but with RAX120 AX12 connected to a CM1150V. I
have xfinity blast 300MBS. I have one own cable pedestal (long story), which is on my property and is linked with a RG61 copper cable. I live in a semi-rural area. I have many (5) 8 port subnets about >50 ethernet ports in house. I rewired my house in 2016 to use mostly cat7 which was best at that time. I have two bridge routers to cover my house with WiFi and add some more ethernet ports. Will be running a two cat8 a cables soon from bridge routers to RAX120.
1) I initially set up my new router cable modem using the 1 gb port. Was stable but speed was a little disappointing at 230Mbps. It was slow compared to what I use to get with my linksys router. I use to get 275Mbps with 6 year old linksys 8100, Xfinity up my speed to 300Mbps/DOCSIS 3.1. Hence I decided to try a netgear router/cable modem because I not excited about linksys mesh solutions.
2) Hooked up the WAN Aggregation two wire (Cat7) about two weeks ago to gain more speed. Speed improved to about 270Mbps but after 10 hours or so would drop to 25Mbps in my test. I reboot would always up the speed back to ~270mbs.
3) I just reconfigured my RAX120/CM1150v to use the 1 Gbps ports. Speed has been a little bit better ~370Mbps. I am currently not using the 5Gb ethernet port, I am thinking about to use it to hook one of my subnets too. They Leviton 10/100Mbps subnets.
4) All firmware are up to date.
Any help in getting the WAN Aggregate working?
Shelby500GT
