4estOC
Jan 08, 2020Guide
CM1200 to Rax200 WAN aggregation slows down (requires reboot)
I have a CM1200 modem and RAX200 Router with WAN agreggation (2Gig). My internet speeds slow down to 25Mb after approx 24 hours. Rebooting the router fixes the issue for another 24 hours and then the...
dayjob
May 23, 2020Guide
nEo717 wrote:Seems lots of us at having the same issue -- I have RAX120 (firmware v1.0.1.122) with CM1200 Modem -- WAN Aggregation works great (up to always near 1200 mbps) for half day to day, and then top download speed goes to 18 mbps -- Reboot the RAX120 and speed goes back up again, only to repeat.
Personally I don't buy the idea that its in Cable Modem firmware -- if that was so, a reboot of the Cable Modem should resolve the issue (and it doesn't) -- tp link Archer C5400X seems to be the only WAN Aggregation Router I can find that doesn't have this issue.
But a reboot of the modem does work. I can reboot either the modem or the router and it will fix (no need for both). I put my modem on a smart switch and have it power cycle the modem to address this issue (its timer based since I have no way to automate detection of the drop yet).
sharpened
May 23, 2020Tutor
Just a reminder, simply unplugging and replugging in one of the Ethernet cables also fixes the issue. Still annoying, but slightly faster.
