4estOC
Jan 08, 2020Guide
CM1200 to Rax200 WAN aggregation slows down (requires reboot)
I have a CM1200 modem and RAX200 Router with WAN agreggation (2Gig). My internet speeds slow down to 25Mb after approx 24 hours. Rebooting the router fixes the issue for another 24 hours and then the...
4estOC
Jul 08, 2020Guide
You should really return both of them and pre-order the CAX80. Simplest solution.
nEo717
Jul 08, 2020Guide
CAX80 arrives today... will be interesting see how it works — for all in one device the router firmware is different than modem which is interesting
- michaelkenwardJul 08, 2020Guru - Experienced User
nEo717 wrote:
....for all in one device the router firmware is different than modem which is interestingIt always is.
For example, there is a big problem with cable modems. Only ISPs can update that. Thus blocking Netgear from providing updates.
