4estOC
Jan 08, 2020Guide
CM1200 to Rax200 WAN aggregation slows down (requires reboot)
I have a CM1200 modem and RAX200 Router with WAN agreggation (2Gig). My internet speeds slow down to 25Mb after approx 24 hours. Rebooting the router fixes the issue for another 24 hours and then the...
Shelby500GT_x
Jul 08, 2020Tutor
All
My recommendations would be the Asus GT-AX11000 Wi-Fi 6 Router paired with cm1200. I heard it works. Hence the issue we have is netgear hasn't communicate anything about the "fix". Their release notes state that there are no issues but we know there is an issue. It's been going on for months and the rumor is they have "fix" but it to my understanding hasn't been stated anywhere. The rumor is the cable modem fixes the problem even though the cable modem works with other routers. My guess is the modem "fix" is to force a disconnect once a day or so. That forces router to rebuild the connection stack. We know that if you pull the cable from the router to the cable modem it starts to work again for about a day.
nEo717
Jul 23, 2020Guide
I switched to now to Netgear CAX80 -- Its the first Modem/Router I've found to be acceptable (let alone its actually pretty good) -- speed tests run around 1208 Mb/s now and never a need to reboot -- Bufferbloat bounces around from A to C is only thing that could use some work (but then again that's a problem for most devices like this). I'm using the Mult-gig port to connect to 10G switch which elimates any need at all for any link aggregation.
