4estOC
Jan 08, 2020Guide
CM1200 to Rax200 WAN aggregation slows down (requires reboot)
I have a CM1200 modem and RAX200 Router with WAN agreggation (2Gig). My internet speeds slow down to 25Mb after approx 24 hours. Rebooting the router fixes the issue for another 24 hours and then the...
michaelkenward
Sep 25, 2020Guru - Experienced User
behshad wrote:
Looking for release notes for V3.02.01 and not published on NetGear yet.
It won't be. Netgear cannot publish firmware for CMXXXX devices because cable ISPs don't allow it.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
behshad
Oct 01, 2020Tutor
That is correct, firmware is pushed by ISP. However Netgear has a page which points to a Netgear knowledge base on CM1200 firmware:
https://www.netgear.com/support/product/cm1200.aspx#download
The Netgear knowledge base shows the Comcast deployed firmware for CM1200 product (and other netgear products and service providers):
Knowlege base's last update is 9/22 and still shows the old firmware.
