Windbreaker1976
Jun 22, 2020Aspirant
CM700 Cable Modem Loses Connection to AX12 Nighthawk Router Randomly
Hello, The subject pretty much says it all. Every so often, sometimes a couple of times a day, sometimes a couple of times a week, my cable modem and router stop talking to each other. The ethern...
Jun 22, 2020Guru - Experienced User
Does a wired PC directly to the modem do the same thing?
Swap out the LAN cable between the modem and router. CAT6 is recommended.
Has a full reset on the modem and router been performed and setup from scratch?
- Windbreaker1976Jun 22, 2020Aspirant
With respect to PC connected directly to modem it's hard to figure that out as we have so many computers and devices running off that router and I can go days without it happening. I have the new cable so the next time it happens I'm going to swap out the cables and see if that fixes it rather than a couple of reboots of the modem. I know I've reset the router a few times but not sure about the modem. Probably not the modem, however.
