Windbreaker1976
Jun 22, 2020Aspirant
CM700 Cable Modem Loses Connection to AX12 Nighthawk Router Randomly
Hello, The subject pretty much says it all. Every so often, sometimes a couple of times a day, sometimes a couple of times a week, my cable modem and router stop talking to each other. The ethern...
Jun 22, 2020Guru - Experienced User
Does a wired PC directly to the modem do the same thing?
Swap out the LAN cable between the modem and router. CAT6 is recommended.
Has a full reset on the modem and router been performed and setup from scratch?
Windbreaker1976
With respect to PC connected directly to modem it's hard to figure that out as we have so many computers and devices running off that router and I can go days without it happening. I have the new cable so the next time it happens I'm going to swap out the cables and see if that fixes it rather than a couple of reboots of the modem. I know I've reset the router a few times but not sure about the modem. Probably not the modem, however.
