Retired_Member
Oct 11, 2021Combine 2.4GHz and 5Ghz into single Band
Having trouble figuring this out. Currently, it appears that my network has been split between 2.4GHz and 5GHz. I have two network names to choose from in my Wifi list Kamaaina Kamaaina-5G B...
Retired_Member
Oct 11, 2021- Retired_MemberOct 11, 2021
I cant get the picture to show. but it shows both GHz and Smart Connect is enabled.
- plemansOct 12, 2021Guru - Experienced User
what firmware version are you on?
Have you tried a simple factory reset and reinstall? Sometimes that fixes issues like this.
