captain_tinker
Dec 21, 2021Initiate
Commercial Electric Smart Plug Can't Set Up
I have a couple of Commercial Electric smart plugs I got at Home Depot last year for my Christmas lights. I had a D-Link AC router at the time. I got them set up and they worked fine for the season...
- Dec 22, 2021
Thanks for the suggestions, but they didn't work. However, as I was trying them, I noticed something that I hadn't tried yet. I saw that the security for the 2.4 ghz band was set to WPA2-Personal[AES] + WPA3-Personal, and I wondered if maybe I should try setting it to just WPA2-PSK [AES] so it wouldn't attempt to use WPA3. Once I set this and rebooted the router, I was finally able to add the plug, with all that other stuff set back to where it was originally. So none of the beamforming and MIMO and AX settings affected it, just the security for the password. Now, it's possible though that some of that stuff may still make a bit of a difference as the response to the plugs is very slow! The router isn't that far from them and not through many walls. I'd say within about 20 feet or less away. But it does work. Hopefully this might help someone else if they have the same issues...
captain_tinker
Dec 22, 2021Initiate
Dec 22, 2021Guru - Experienced User
Ah, didn't think of that ether. I found same thing happening with my R7800 in bridge mode. Would NOT connect to my RAXE500 with Mixed WPA2/3 mode set. Had to set WPA2 only then it connected.
Thanks for letting us know. Will keep this one in mind.
Enjoy. 📡
