Jonowl
Sep 21, 2020Aspirant
Completely remove Circle from RAX80
Hi there, bought a RAX80 and I foolishly installed the Circle app. I won't go into all the immense problems this caused, but I really want to delete it and any options that may have (by default) ...
Christian_R
Sep 25, 2020NETGEAR Employee Retired
Hi Jonowl,
You may factory reset your router and run through the setup assistant again.
Christian
