Itree86's avatar
Itree86
Configuration issue detected on ZTE N985
So i keep getting this push notification on my phone. A few things that concern me... I dont own any zte devices and neither does my significant other. Also when i try to find the device or anything on it there is no device in the device history on my router.  What can i do to solve this problem and can a device with configuration be intentionally set this way to exploit?
  • plemans's avatar
    What is telling you this?
    What router?
    What service?
    A bit more details help on whats going on
    • Itree86's avatar
      Itree86
      a push notification on my phone through the netgear nighthawk app or the armor app not sure which one
    • Itree86's avatar
      Itree86
      The router is a nighthawk ax4 ax3000-4- stream router model rax35
      • plemans's avatar
        are you able to open it and check the IP address for the notice?
        To compare to the other devices on your network? It wouldn't be the first time something was mis-identified on those.
        I've got a IoT device that ID's as a storage device.
  • michaelkenward's avatar
    michaelkenward
    What tells you that this has anything to do with your unknown Netgear hardware on your unknown phone?
    • Itree86's avatar
      Itree86
      Oh im not sure i am completely ignorant of this issue. I am trying not to be paranoid and bug out thinking my network has been hacked but i or no one i know owns a zte device and then when i go to look for this device i can never find it
