plink53
Jun 05, 2021Aspirant
configure ax4300 as wifi extender
Has anyone tried using a RAX45, AX6, AX4300 (all reference same product) as a WiFi extender to another AX4300? I found a service article, https://kb.netgear.com/24108/How-do-I-enable-the-extender-mod...
- Jun 05, 2021
The MK63 system supports wired backhaul.
antinode
Jun 05, 2021Guru
> [...] as a WiFi extender [...] ethernet instead of wireless [...]
That's not what "extender" normally means.
> [...] I bought a Netgear mesh system [...]
Did that "a Netgear mesh system" have a model number? Look for
"Model" on the product label. If so, then visit
http://netgear.com/support , put in your (actual) model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"access point".
plink53
Actually it is. I used this configuration on old Apple Airport Extremes. The second/extender Airport was connected to a ethernet network providing a faster and more consistent backhaul capability than using a wireless signal. Apple had a simple way of configuring the satellite/extender Airport (it just worked). The article I mentioned provides some configuration settings but not as easy as simply using the Netgear Nighthawk iOS app.
The mesh system I bought but haven't installed is an MX63. I asked about using an ethernet network for this system as well but it doesn't appear the ethernet port on the satellites can be used for the backhaul connection, only for hardwired devices without WiFi.
I did read the manuals for the AX4300 and they don't mention anything about using it as a WiFi extender but do mention other Netgear products that do work.
