GoldenJ
Feb 17, 2024Guide
conflict IP address after power failure
In my RAX45 router, I reserved some IP addresses for specific devices while leaving the others to be determined by DHCP. However, after a power outage, a reversed IP address was assigned to two diffe...
- Feb 17, 2024You have to restart the device(s) so they can request a new IP from the DHCP which will then give out the reserved one. Restarting the router won't do it
Feb 17, 2024Guru - Experienced User
Ok. Something you might do for those two devcies Setup a static IP address outside of the routers default IP address pool. Some devices like NAS and AVRs don't need much or any router management and recommend setting a static IP address on these devices. You'll need to change the routers IP address pool size. I recommend .100 to .200. Then you'll have room on either side of this pool for static IP addressed devices.
What I use for my NAS and AVR and others like printers and cameras.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
GoldenJ
Feb 17, 2024Guide
Thanks a lot for the advice!
