1jhill
Feb 29, 2020Aspirant
confused by rax120 options
ok so got my new rax120 and im confused by some setup options. In wireless section there is enable or disable AX and if enabled it says it enables OFDMA however below that it has enable OFDMA for...
1jhill
Ok. As for 5g Chanel is there a reason to use the upper channel like 153? I read somewhere that some features need DFS Chanel to function? Also if I use ht80 which I guess I'm going to have to is that giving me (for my pc) the 80+80 so I'm at least taking advantage of that and didn't just make my router a wifi5 router.
Newfiedrool
Feb 29, 2020Virtuoso
When you use AX 5Ghz and AX is enabled then just select ht80 which is going to be good. You don't require 160.
DFS is good if you have a congested area ie neighbouring channels or you use an extender like an EX8000 where it requires a high DFS to allow the 1733 backhaul link. Over here in the U.K. we have a small penalty when using DFS and I use channel 100 as I've an EX8000 extender. The only downside is if it detects Radar it kicks you off the DFS channels.
all AX functions are at work and don't require a DFS channel. Have a play and try out stuff. If you have a phone look for WIFI SweetSpot which will show your connection rate, don't confuse this with your internet speed. Just play with the router and try it out and see what works for you.
